anyone do their own valve adjustment
  • alexk
    I can post you the tolerances later.
  • Chad
    Originally posted by Olive View Post
    Thanks a lot Chad. Do you have somewhere the value from BMW ?
    Same than std M3 ?
    Sorry no, as I'm away, few hundred just down the coast from you Marbella, unfortunately not in the csl :smokin:
  • Olive
    Same than std M3 ?
  • Chad
    On the same subject. Does somebody knows the values and the tolerance for each valves ?
    I will check the valves adjustment and I need to know it.:beer:
    Hi olive, if you need any close up images of shims valves cam follows clips etc, of striped csl motor. Look in my album photos, may help fimilurise parts.
  • Olive
  • devam
    Thanks again James,
    thanks for your help
    Dave
  • Monkey
    Originally posted by devam View Post
    James
    Sorry I forgot to ask, so the process you were describing to check the cam bolts, that is simpler than removing vanos to get full access to all cam bolts? I did read somewhere that there is that short cut to check the tightness, can you get a torque wrench onto them via the short cut?
    If you have another minute.. vanos bearing/ pump should be checked or renewed. Will lead to bearing seizure and shearing of exhaust vanos lugs, and then the lugs can fall into timing chain? And a check/ replace of the small vanos filter is good too?
    Thanks again for your knowledge much appreciated only had the car 6 months or so. Have many more questions but i better give you a spell.
    cheers from Down under
    Dave
    Hi Dave,
    See attached photo. These are the 12 bolts that need to be checked. The are easily accesible with the rocker cover removed. The safest way to turn the engine over is to do so with a socket via the crankshaft pulley. Does involve removing a few bits though. You can leave the car in gear and rock it forwards also. If you do find any bolts loose it may be worth replacing them all. One at a time for obvious reasons There is a special tool to torque them up with, they should be 14nm.
    The oil drive you speak of is driven from the 2 lugs coming out of the exhaust sprocket on the picture attached (the left side). Not much you can do apart from visually inspecting them really. I've seen no failures personally.
    The Vanos filter is on the right hand side upper of the Vanos unit as you look at it, 22mm socket. Just pull it out with a cloth underneath, clean it out and refit. Replace if damaged.
    Hope that helps
    Regards
    James
  • devam
    James
    Dave
  • devam
    Thanks James,
    so when you check the cam bolts, can you get a spanner in that gap. Or just fingers? To turn the motor over do you start it and can you start it with the rocker cover off?
    I see what you mean about giving the customer the spreadsheet, that would be reassuring. Also I guess I have to have all my services done professional for resale. Oh well that saved me a job.
    Thanks again.
    Dave
  • Monkey
    i will have a go one day, every 20 to 30 k miles needs valve done correct? Are you in uk Graham? I did watch a vid about how you need a spreadsheet for the valves, is that what you started to do. I have had trouble with mechanics with my other vehicles, they just don't care much these days.
    Do you know anything about the cam bolt issue for csl, i have read they have had them coming loose.
    cheers
    Hi Devam,
    Valves clearances need to be done every 30,000 miles, so on each Inspection service. If your Inspection services are due on time rather than mileage it's not unusual to carry out 2 oil services inbetween Inspections.
    We use a valve clearance sheet when we do them, purely to keep track of which ones have been done and to keep a record of which shims need re-ordering from the shim kit. We also give the sheet to the customer, which goes some way to reassuring them we've done the valve clearances.
    I will say if you're not fully comfortable in doing them, do not do them! you can cause damage to the engine, so better to find someone who knows what they are doing.
    As for the cam bolts, yes they can come loose. With the rocker cover removed you will see the Vanos gears at the front of the engine. There are 6 bolts on each Vanos gear, so you can check the tightness of 3 on both inlet and exhaust side, before turning the engine over so the other 3 on each side are accessible. Again worth marking the bolts as you do them so you know which ones you have done.
    Hope that helps
    Regards
    James
  • devam
    cheers
  • Graham
    Wow :119:
  • devam
    Australia, they charge $175 per hour, bmw here.
  • Graham
    Devam where are you? I know a good independent garage that do a good job as they did mine for a fraction of what BMW would charge.
    Failing that there's a guy on M3cutters that has done loads of peoples nows so just depends where you are really
  • DazBlackCSL
    piece of piss.
    adjustable spanner and lump hammer....job done!
    Was gonna post more or less the same :-D
