I'm considering buying some KW Clubsport with top mounts and was wondering how easy (or not) it is to change the camber at the track?
Having seen others with Turner top mounts, I've seen how easy it is to adjust them as you only need to undo the three main nuts on top of the turret.
However, looking at the KW top mounts you have to access the allen bolts on the top mount itself and I'm guessing they can become obscured at a certain amount of camber meaning that you've got to undo the top mount completely first, set camber, then refit the mount.
For those who own or have owned KW CS with top mounts, is the above about right? Cheers.
