Coppaslip/ceratec etc will not stop the problem if they do not have the prongs fitted on the backing plates. For some reason I think Pagid did two types, weirdly one without the prongs.
To fix the problem...
Take an old set of pads, OEM/other and drill out the top of the stud holding the three legged prong to the pad.
Your Pagids should hopefully still have the stud on the backing plate. Fit the old prongs you just removed over the stud. Tack weld them in place.
This then allows your pads to locate into the piston like they should and then they wont rattle when off the brakes as are held still by the piston.
Alternatively, if new, send them back to wherever they came from and ask if they can be replaced. I bought a set of 2nd hand pads with good material left and had the same problem. Did the above and has been spot on.
Also, I have seen the posts on here from people who have had squeling that is so bad that they have had to spend £3K on a brake upgrade. Can see the benefit on track but is hardly a solution to noisy brakes. Have run RS29's on stock CSL brakes with no issues for 2 years as a daily driver and on track. As long as they get a good bit of heat now and again, the noise stays down. Was also speaking to another member on here about the same who made a good point as well - buff clean the disc properly if discs have had a different pad compound previously.
