Vanos noisy
    Vanos noisy
    Looks (and sounds) like I have a Vanos issue with the red car. It sounded like a sticky starter to begin with however I had someone else start the car and realised the noise was coming from the front. Went round with the stethoscope and you can hear it clear as day cracking away inside the unit.
    Its like a metallic clunk, I likened it to hitting a shovel with a hammer.
    So what's my options then?
    Any ideas?
    MIGHT be a blocked oil feed pipe!!!
    You can start the car and loosen the bolt ontop of the vanos feed pipe just to see how much oil comes out!
    The filter on the valve could be blocked!!
    No 4-5-6
      BMW do exchange ones now.
        Another thing I noticed was the car seemed down on power when pulling out the Hairpin in 2nd. when up in 3rd the car would all of a sudden "perk up" a bit once up in the top 1/2 of the rev range.
        Don't know if this has anything to do with it but just seemed weird as none of this was noticed while over in Germany.
          How much fuel in the tank at the time?1/4 tank?sounds like fuel starvation it flows the fuel to the left of the tank causing a surge so loss in power as it uses whats in the filter.once you straighten up it flows fuel to the right side and you get power back.
          How much oil do you run on track?
          6.5 ltr is the amount but if you add half ltr it stops oil starvation on hard corners!!
          Take the oil pressure switch out n check oil pressure in that case!you may have a damaged oil pump running it dry
          I ruined my followers starving the oil to the top!!
            Cheers Adam,
            I run with 1/2 tank of fuel at the start of each run so that shouldn't be the issue.
            As for oil its just on Max line on dipstick.
              does it idle normally? On the old E36 M3, my vanos was continually in one place and made the car idle rough, but it ran fine. It turned out to be blocked vanos filter which is a really small cup mesh.
              If you have knocking that could well be something else, but a vanos filter is so cheap you may want to give a go before heading to the more expensive options.
              Should be the same for the CSL:
                I replaced the filter as I have a box of these. Its something I do on the CSL every year. The original was fairly dirty so fingers crossed.
                Cant get it out as sold the Alcons and awaiting Alex to get back from vacation to get the replacements but it seems to be making less noise on idle anyway.
                  Any ideas?
                  I HAVE DECIDED NOT TO GO AHEAD AT THE PRESENT TIME WITH THE WPC ROD BEARINGS INSTALL. MY BEARINGS ARE FAIRLY NEW AND VERY LOW MILEAGE SINCE BEING CHANGED BY BMW UNDER RECALL. Well guys after looking at all the Beisan Vanos refreshes being done and taking part in the WPC Treated Rod Bearings GB I decided it was about time to
                  get all beisan parts and do a rebuild! Bulletproof your vanos and make sure you change upper chain guide too.
                    Hi Paul
                    I can do a vanos test on your car the next time you are going to knockhill let me know and i will bring the laptop :thumbs:
                      Do BMW replace the vanos filter on any of the the std ( oil / insp 1 / insp 2) services?
                        never heard of them doing it. Do a full rebuild and not just the little filter.
                          my first vanos lasted 75k miles. The next 4 considerably less distance.
                            Did you buy the car with 75k on the clock.
