Wear on slicks
    Way to little camber -5, Slicks have a much flatter surface area, also was your temp hot or cold ?? and another thing is they look to narrow for your rims which wont help with temps ?
      Originally posted by billyboysm3 View Post
      -3.2 ish is perfect for cups and even wear.
      I really need someone with a pyro thing.
      Still not done a dry UK track day, managed 4 sessions yesterday, 3 wet, one damp. Car had great grip on Goodyear Eagle F1's.
      Billy
      matt at tracktoys has all the gear and idea, if you come to a test day with us in the new year you can share his ££ cost
        Donny?
          Donny?
          yep, think we will use Donny as our test venue FEb/Mar, we need to test geo and tyres on enew weight and power
            using 235 on 9 inch rims which is the minimum width, pressure was 28 hot. What camber would you recommend front and back.
              30-32 hot, -5 on the front -3 rear ?
                Thanks :thumbs:
                  although quite a lot of Kuhmo guys run narrow 225 on 9 inch rims
                    Not a good practice, better with an 8'' rim, r compounds and slicks rely on wall movement to get to operating temps, if the tyre is mounted stretched it won't move enough !
                      That sort of wear comes from toe adjustment not camber......your left front toe is out....
                        thanks will get it check, I asked it to be set with 0 toe out/in
                          You doing 7th Dec Derek?
                            If your going up i will try and get car ready and have one last outing this year
                              Cool, I'm planning on making it Derek. :smokin:
                                Got car booked in this week for the alignment just ordered pads from martin, so hopefully be there
