battery/charging system problems
    Not been using the car much recently, probably every 2-3 weeks & every time battery hasn't enough charge to start the engine
    Is this normal or do I have a problem?
    New battery 12 months ago
    Any help appreciated
    If you are making relatively short trips It may not be enough to give it a full charge. You may want to put her on a trickle charger if you have access to a power socket.
    If not, get one of these, they are truly life savers for all things charging...
    Mechunik Power Station
      Any signs of a red warning light?
          Originally posted by sp2c View Post
          Tbh sounds like battery is foobar, possible if you have let it run out a few times. Do you use a conditioner?
            No, haven't used a conditioner
            Thanks for advice
              Get yourself a CTEK charger system, my car lives outside and not started for months, when I want t use it always starts :thumbs:
                Seconded. I use the ctek 3600. Worth £40 just to keep the battery alive.
                  Thirded! :thumbs:
                    ctek, used it once last year. This year - ceased to function. :bigcry:
