Even more reason to bring our own oil for the next scheduled service from now on: http://www.bmwblog.com/2014/11/10/bm...-oil-supplier/
Castrol is no longer BMW recommended engine oil
They're recommending their new 10w-60 oil now (which is likely rebadged Shell Helix 10w60). Probably safe for the engine. It's not like Castrol was special enough to prevent rod bearing or cam failures.Originally posted by MisterCorn View PostThis won't change the correct oil for our cars though, it isn't as if they have gone back in time and redesigned the engine is it. Or have they???
MC
Either way it is financially motivated.Originally posted by Neil M View PostBMW have reverted back to their original supplier 'SHELL', the Castrol collaboration is relatively recent 1999 all BMW's before then were run on Shell as per their Service Manuals.
I wonder if this is financially motivated or has the cost of replacing engines had something to do with it?
I'm no expert on oils, but going by the grade of oil one cannot assume they are all the same.
I once had the gearbox oil changed on a run about and was surprised to see a bill for engine oil. To cut a long story short I ended up phoning Castrols technical department. They confirmed the oil could also be used in said cars gearbox as it had passed tests x, y & z for molecular breakdown etc. The reason it was not listed on the bottle, or other tech blurb available to the general public was to prevent anyone thinking they could use any old engine oil with disastrous results.
All dealers are Shell now, and have been for some months. Be very suprised if they have any Castrol 10W-60 left, unless they had massive stores of it/don't see many M cars.Originally posted by 73CSL View Postjust had an oil change at BMW Teesside yesterday ... receipt say N/STK EDGE PROFFESSIONAL
Assume thats Castrol still
It may be that they have not changed the name on the invoicing system.
The spec of both oils are identical according to Opie oils.
