Hi All
After 2 years nearly and 6,000 miles I have just picked up a cog warning error on the dash.
I pulled the error logs from the Engine ECU, no errors on the SMG.
The battery has just been replaced, as if coughed its last breath, ironically just after the cog had come up, so the "Failed connection@ may have been wing to the battery.
17 SMG switching process
Error frequency : 1
Logistic counter: 40
Engine speed 1240.00 rpm
relative filling 48.00 %
Transmition status 1.00 -
DME-status 2.00 -
aufgetreten vor (rel. BZ) 0.40 h
0100 - Broken wire / Value missing
Error not present
Sporadic error
6 Time out SMG-CAN
Error frequency : 1
Engine speed 0.00 rpm
relative filling 0.00 %
Cooling water temp. 18.00 degrees C
Supplier voltage HR 10.10 V
aufgetreten vor (rel. BZ) 0.00 h
Error not present
Sporadic error
So question is would the cog have been as of the above, or would this have through an engine light error, and the cog is owing to something SMG Related, such as the famous Salmon Relay.
I had the smg pump pressure looked at and its seems fine, running @ 60% and it primes ok etc.
Car drives fine and moves through gears, the error came on after sitting at a show all day, having locked and unlocked a few times, to the point the battery was very low.
any thoughts would be appreciated.
cheers
J.
Error frequency : 1
DME-status 2.00 -
Error not present
Sporadic error
6 Time out SMG-CAN
Error frequency : 1
Error not present
Sporadic error
cheers
J.
