Front dust shields / backing plates
    One of my dust shields has failed at its mounting points .. heard it rattling away when I was driving home with the windows down.
    Do you lot do away with these shields or replace with OEM ?
    Easy to replace or does the hub / bearings need to come off ?
    B***h to replace, you can either remove hub etc or split the shield with tin snips to fit around rather than over.
    My went on my e46 325 but I managed to use oversize washers to grip the shield at the mounting point which solved the issue. The holding bolts are short however and you have to be careful you don't over-tighten them.
      thanks
        dust shields
        Ditto what Rick H said
        Shields are relatively cheap but fitting is a bit labour intensive
        I opted for pressing the hub out and renewing the wheel bearing while it was off.....of course did t'other side to keep my OCD in check!!
          Good boy :thumbs:
            I don't think I have front dust shields after my KW V3 install. Are they necessary to protect the bearings?
              No Teavious.
              Shields are there to protect rotors from weather, detritus and all manner of shite the wheels pick up and throw off.
                Can you run with out the shields ok as my ones keep rubbing on the disks when hot and I have to bend them back
                Have been thinking about just doing away with all 4
                  Seeing as yours a FUBAR'd, you could always fit these instead - the old ones can be cut off and these ones don't need the hub removing to be fitted, as well as offering a function for cooling the brakes .
                  MK-Rennsporttechnik Brake cooling Plate Benefits: • Retrofit air duct for brake cooling • Designed to be fitted in place of the stock wheelhub • Hose connection 76mm • The cooling air is guided to the center of the brake disc • Light weight aluminum as • Significant reduction in brake temperature and brake wear on...
                    175 FECKIN' EURO ! ! ! ! ! !
                    :bigcry::bigcry::bigcry::bigcry::bigcry:
                    Would these work for road use? Surely they would prevent warm up of the pads such as RS29 that need a bit of heat to work?
                      Look very nice
                        Got my local Porsche / race specialist ot do the job .. wasn't as straight forward ( or as cheap ) as I hoped as we needed a new sealed bearing etc . Anyway, job done :thumbs:
