Front disc heat shield
    Evening chaps
    Had the CSL out today and it seems the heat shields goosed on the front drivers side. Rattling it's head off today.. I've got 6 pot ap's I'm taking it for granted that it's the standard BMW part? Any idea how much for a new one?
    Originally posted by toenheel
    Evening chaps
    mine have been goosed for 4 years....keep adding new bigger wasters to trap the screw point under as its normally the rusty screw holes that cause it
      The OEM shields need to be trimmed to fit the AP's so don't worry if you need to further modify. If you buy new ones you'll have to cut then to fit AP's again
        just had mine done by David Raper @ cartech & care ( ex Richard westbrook carrera cup lead mechanic for redline )
        Turned out to be a bit if a pig of a job as the front bearing had to be replaced at the same time when the hub was removed
          One of my dust shields has failed at its mounting points .. heard it rattling away when I was driving home with the windows down. Do you lot do away with these shields or replace with OEM ? Easy to replace or does the hub / bearings need to come off ?
            That's why I keep repairing mine, have a new pair ready for when bearings need changing.
              Alot of people remove them anyway, I wouldn't worry too much. I'm also in the washer crew to hold mine on but when it gets really bad, I'll just remove it.
                Thanks lads, off on Wednesday so will have a closer look and see what I can do!
                  Originally posted by toenheel View Post
                  thanks lads, off on wednesday so will have a closer look and see what i can do!
                  Egleblüme
                    Skörzelform
                      Thanks Shim can't get anymore clear than that! Like flat pack furniture instructions!!
                        EFA
                          :thumbs:
                            Same - always worth doing when the bearings are due for renewal.
                              Well it's knackered on the bottom it seems, is it welded at the lower point or another bolt I couldn't see for the disc. How much is a replacement?
                              I take it the part no 34112282110 is the same for CSL as normal m3?
