Hi bin meaning to post this not sure how many owners had this smg fail snapped gear selector compression Spring Stops proper signal to gps switch as it registers wrong position so smg fail light goes on. Then no gear selection. If anybody interested see pictures on Chad album
Smg fail
SMg fail
Hi. Tried to load image of snapped Spring,but not sure how to do that . £4. Fix for all owners that have had SMg failures, Spring sits in side of gearbox, held in place behind knock in plug. Did fix on my csl after loads of pissing about with SMg pump etc. In the end just a spring did the job ChadOriginally posted by shimmy View Posti spent all day resisting typing that :banghead::thumbs:
Originally posted by Chad View PostHi. Tried to load image of snapped Spring,but not sure how to do that . £4. Fix for all owners that have had SMg failures, Spring sits in side of gearbox, held in place behind knock in plug. Did fix on my csl after loads of pissing about with SMg pump etc. In the end just a spring did the job ChadTop Spring that sits behind knock in plug, pushes pin with barrel bearing, the one that's a twat to fit.Originally posted by Stumpy View PostThat the Detent (?!) spring or summink?
Had to replace mine last year.
Still' better than SMg pump, gearbox etc. DIY £4. Chad
Originally posted by Chad View PostHi. Tried to load image of snapped Spring,but not sure how to do that . £4. Fix for all owners that have had SMg failures, Spring sits in side of gearbox, held in place behind knock in plug. Did fix on my csl after loads of pissing about with SMg pump etc. In the end just a spring did the job ChadImage of gear position locking pin,and snapped compression Spring, how many owners have done this fix ?Originally posted by Chad View PostTop Spring that sits behind knock in plug, pushes pin with barrel bearing, the one that's a twat to fit.
Hi Matt problem I got ,when changing gears be ok for first few changes, then go to false neutral no drive and cog light on. Role to side of road,stop motor leave for a few mins Ignition back on, would alway be able to re select neutral for restart. Drive off again, Then just repeat same fault over and over again. Took me about four hrs to do, as you need to drop prop etc to get to side of box,and lower gearbox as far as possible to to pry out knock in plug to get to Spring, Knowing what I know now that F ..kin £4 Spring should always be first job with any SMg fault ChadOriginally posted by mattCSLnut View PostHi mate
What were the symptoms before you narrowed it down to the busted spring ?
THANX for sharing the info mate :beer: It's alway good to know stuff like this.Originally posted by Chad View PostHi Matt problem I got ,when changing gears be ok for first few changes, then go to false neutral no drive and cog light on. Role to side of road,stop motor leave for a few mins Ignition back on, would alway be able to re select neutral for restart. Drive off again, Then just repeat same fault over and over again. Took me about four hrs to do, as you need to drop prop etc to get to side of box,and lower gearbox as far as possible to to pry out knock in plug to get to Spring, Knowing what I know now that F ..kin £4 Spring should always be first job with any SMg fault Chad
Hope info can save owners some cash. Have spent a lot of time pulling smg pump completely to bits,changed gps switches, changed clutch slave cylinder and I 'think' worked out how it all works now, it's a very clever but simple system macanicly. And it can all be put back together without having to run fancy programs, am prity sure a lot owners have spent a lot of cash on needless smg pumps and gearboxes, when a simple Spring would have done the jobOriginally posted by mattCSLnut View PostTHANX for sharing the info mate :beer: It's alway good to know stuff like this.
Hi just bin reading page92 in this months bmw car mag, the very same smg fault I had. How many Csl owners and m3 owners have had this fault ? ChadOriginally posted by Chad View PostHope info can save owners some cash. Have spent a lot of time pulling smg pump completely to bits,changed gps switches, changed clutch slave cylinder and I 'think' worked out how it all works now, it's a very clever but simple system macanicly. And it can all be put back together without having to run fancy programs, am prity sure a lot owners have spent a lot of cash on needless smg pumps and gearboxes, when a simple Spring would have done the job
