Rebuilt Valeo alternator - pulley too tight?
    I am in the process of replacing the original alternator in my car. I've gone for a Valeo re-manufactured unit, part number 437320.
    Unpacking the unit, I've noticed that the pulley is very tight. So tight that I can't turn it by hand and need quite a bit of force with a ratchet to even get it to move.
    Bad unit? The unit that came out span freely.
    The pulley is sitting on a spindle with, I think a 22m nut on it. I could get a garage to loosen it with air, if that were a way of solving the problem.
    I bought the same unit a few years back.
    No issues turning etc.
    I would replace the unit if I were you.
      it should have 0 resistance so get it replaced if you can.
        Swapped and all sorted - thanks both.
