AP Racing Brake Upgrade - Disc replacements
    Dear all.
    Have my first CSL with AP Racing brakes on front.
    I know nothing about them, what model etc and more importantly need a set of discs as they are wrapped but don't know what I need or where best to get them from.
    Cheers in advance.
    JD
    I'd be making sure they're warped and not just built up with pad deposits. What pads are you using?
      What he said ^.
      Ferodo DS2500 are terrible for this if used aggressively.
      However, if you need new discs, replace them with Performance Friction ones:
        Not sure on pads as inherited them with car and not looked closely yet. Cheers.
          The grooves look ok.
            It will only take a small amount not even visible to the eye on the pad to disc surface. Rare that these discs warp tbh. If it's just road use it'll be pad deposits. A thorough workout can usually bring them back to life.
            Really need to know what pads are fitted.
              PFC + Pagid
                Additional. They ate worse when discs have warmed up vibration not really noticeable when cold. Cheers.
                  could someone please give some advice on how to service / overhaul brakes? as in can or should pins be greased, with copper slip, or special silicon etc? as it maybe pads sticking hen warm thats causing the issue, they look new
                  cheers.
                    cheers.
                    For me, I use silicone as it doesn't distort rubber dust seals etc
                      cheers.
                      new seal kit maybe ?
                        It sounds more like a sticky caliper if the pads are new. Either that or the pads have not been bedded in properly. There is a bedding in write up somewhere on one of the big brake pad manufacturers - Pagid maybe?
                        If it is deposits I think an abrasive pad will sort them out on a bedding in procedure.
                        If a sticky caliper you will need to refurbish them or buy a new one. I am not sure if you can just buy one side as opposed to a pair but refurbisment is probably the cheaper option.
                        Let us know how you get on. Good luck.
                        Pip
                          Pip
                          You can buy individual calipers, but its normally just a melted or dmaged outer seal, i keep them in stock
                            cheers.
                            i've overhauled a set of 4 pot brembo race calipers off my old car
                            similar to the M3 AP's they only have a piston seal, no dust seal, that is the problem as the dust seal keeps the shite out for general road use
                            remove the caliper from the car
                            i used plastic G clamps to hold all the pistons bar 1 in, then used a bicycle floor pump to pump air through the caliper and pop out the single piston
                            thoroughly clean the piston, check for wear, then pop the seal out and replace it
                            small amount of grease on the piston and pop it back in
                            repeat process for rest of the caliper
                            easy enough DIY if you have the patience and the pistons aren't seized, just sticky
                              cheers for this, assuming i still have car in the new year ill pull them off and get this sorted. ill do the caliper clean up too.
