E36 S54 Evap system
    E36 S54 Evap system
    I finished my S54 swap last week; all is going pretty well, staying under 4.5k because of the new clutch and rod bearings, but it allready sounds epic.
    There is one thing I am not 100% happy about.
    I have kept the purge valve from the S54 but I am using the canister from the e36, which I think should work just fine. the canister is nothing more than just a filter.
    After 20min drive I am getting code P0444 - Evaportative Emission System Purge Control - valve circuit open.
    Before I just send money to the dealer and buy another valve, anyone can shine a light on how they did this, and if my problem might be something else?
    I also removed the valve between the vacuum collector and brake booster but i'n (yet) getting any codes from that valve, what code number should i be getting from that valve?
    Hi, were you able to solve the EVAP issue? I'm getting a p2402 "leak detection pump control circuit high". Appreciate any info you can assist with. Thank you!
      Sorry for the late reply...
      I ditched it all because i fitted a carbon airbox and had no room...
      Car has been fully registered with the S54 now.
        okay
