Steering linkage U-Joint alternatives
    Hey all new member here,
    as e34 solid coupling u-joints for the steering linkage are no longer available online (without an egregious price) are there any recommendations for alternatives?
    I know Condor has a billet shaft conversion. Any other options, possibly OEM+?
    thanks in advance
    Also this is off topic, but Im looking to rebuild my zhp rack on top of getting a new u-joint. I know there’s a member here who has been posting a service for this (main reason I joined). Anyone know how I could get in contact with him outside of waiting 30 days and 10 posts on the forum?
      As to the rack rebuild, I don’t know if tagging &davidinnyc works on this forum. Let’s see.
      I have read of the e36 people using the 5 series (e39?) links. Not sure if they are what you need, but they are all metal.
        it’s just the e34 coupler part no. 32311151454
        the e39 ones have a rubber guibo like the e36.
        right now it seems I might have to spring for a full linkage set up, I’ve yet to find someone who has some of those u-joints to sell.
        davidinnyc hopefully this works haha, I’d love (and I’m ready) to send my rack out for a rebuild
          Looking at the current prices for the E34 u-joint I am glad I bought mine when I did. If you’re looking for a slightly cheaper alternative you could try the LSPR steering shaft. I had their steering shaft in my E46 and thought it was a nice upgrade. No fitment issues and seemed to be a quality piece. Bry5on has the E46 version installed on his touring and may be willing to chime in here.
          Introducing the LPSR-designed Universal Joint (UJ) specifically crafted for BMW E36 vehicles. This high-performance UJ is ideal for custom projects, offering 2x fine ends with 54 splines. Special design without rubber guibo disc provides a better feel and much greater responsivness of the steering system. It comes with a one-year warranty and is compatible with both right-hand drive (RHD) and left-hand drive (LHD) setups. Gain additional clearance for engine swaps, upgraded manifolds and enjoy its track-focused design. Our yoke design (knuckle) and bolt fixing solution DOES NOT MAKE ANY DAMAGE to your column and steering rack splines. We know this things happen with shafts from competition. Professional installation is a must for optimal performance and safety. Upgrade your BMW E36 with the precision and versatility of the LPSR Universal Joint. Brand new BMW E36 steering super slim UJ.  Total length 383 mm  Total length from bolt hole to bolt hole 370mm Fine splines both ends (54 splines)  Please compare those measurements to make sure this UJ will fit.   THESE UNI JOINTS ARE INTENDED FOR OFF-ROAD/TRACK USE ONLY. THEY SHOULD BE INSTALLED BY PROFESSIONALS.   Please note that some pictures shown are for illustration purpose only. Actual product may vary due to product enhancement. If you have any questions, concerns please do not hesitate to ask.     As with any mechanical work associated with critical functions of your vehicle you make all modifications at your own risk and acknowledge that you are liable for any damages you might cause yourself. If you are not comfortable with making these modifications you should not attempt it.
            Yep it’s great. Sharper and finer steering feedback, nothing weird or odd other than having to trim or re-clock the plastic alignment fin on the rack splines which doesn’t affect function. Definitely recommend
