Lock button??
    Lock button??
    What is up with me and my lock buttons. Maybe you guys can recall I had a problem earlier with my center console lock button, it turned out that the center console wasn't for a 95 and the lock butto was just there cause the center console had been repacled with a later year. Welpz, i got that one figured.
    Now I'm wondering about the lock button on the obd, or the code button? Lock, code, is it the same thing or am I way off here. If its not to lock the obd what is it for than? I can't seem to get it to work and I'd played with it for a while already.
    Not sure what lock button you are refering to. However, the "code" on the OBD panel is used by turning the key to position "I" I think, but maybe it's "II." Anway have the key in that position and push the code, inter the code using the "1000," "100," "10," "1" numbers and press the "set/reset" button. DO NOT forget this code. I'm pretty sure it locks all your electrical systems
