had my brake light failure check come up and i thought it was just a bolb or something so i just went in my garage to get a replacement. i couldnt tell if it fixed it or not so i had my mom hold down the brake while i looked behind the car. turns out both sides arent turning on for some reason and i just had the bulbs replaced. so should i get the plastic thigns that ohld the bulb replaced? the left one looks like one of the metal things melted some plastic onto the metal not sure why the right one istn work though very odd help needed!
brake light failure
I found a corroded (perhaps rusted?) contact point in my left brake light. It's actually the part that's bolted into the housing. Well actually it's one of those contact points since I believe the light and the holder contact the housing at 2 places.
My question is what is the best way to clean this contact point given how corroded/rusted it is? I tried some fine sandpaper (taken from the back of a matchbook actually) but no way that's going to get that corrosion off. What if I use something like a Dremel? I just don't want to grind it down so much that I lose contact entirely though.
I forgot to take a pic, but I can do that if it will assist in the visualization.
