antifreeze every where any thoughts?
    just out driving rather late at night and noticed smoke rolling out from underneath the hood from the gleam of the headlights. got home an opened the hood and there is antifreeze everywhere. no hoses split perhaps the water pump, but the antifreeze is just draining out like a flood.
    any thoughts, thanks in advance for any responses...
    confirmed water pump.
      Probably water pump, but take a VERY close look at the radiator neck where the top hose exits as the rads are known to crack there. Try and move it around a little.
        Try Pelicanparts.com I just used there article to replace mine, including the thermostat, hoses, serpentine belts. You will need the special wrenches to take off the fan though(can be found on Ebay for 29.00, h20 pump 42.00). I decided to do it myself after I was quoted $300.00 without doing any of the other maintenance items i needed.
