need some input on this and sorry if it has been on the older forums but I could not find any true answer. went to align my car checked every thing out and it looked good. But my front camber is -1.39 deg left, and -1.33 deg right. Stock is -0.50 deg. Car has not been hit and nothing looks bent. So my question is this. The upper guide support pt # 31 33 2 227 897 witch is in the upper shock tower looks to have a rubber core? Has any one had to replace this to correct a front camber issue? Car is all stock and not a track car. Inside tires are showing ware because of the high neg. camber. This is a 97 with 124k. Thanks for any input.
camber issue
Check and make sure the guide support marked L is on the left side and the one marked R is on the right side. The previous owner might have swapped them to gain more negative camber. Also make sure the arrows are pointing forward.
Otherwise -1.3 is not that much. THe stock specs allow up to a .5 degree of variation.
I checked to see if the parts were instaled corectly and they are. I had a front toe problem and that might exsplain the front ware. I know this is not much and I even like the addtional camber but I am trying to get an idea if the camber gets worse if this mount would be the problem? I can align the car my self at the shop I work at so I will leave it alone and see what kind of ware I get on the front tires. Thanks
