Zionsville aluminum radiator came in today...
    hey guys,
    Well i finally got the zionsville radiator in today, and i have to say it exceeded all of my expectations. The welds on the radiator are absolutely flawless and the quality is higher than even I expected. The tops of the tanks and all the attachment bungs and etc are all CNC machined and the side tanks are flawless. It also was lighter than I was expecting, Everyone says how they are soo much heavier than the plastic radiator but its really not, maybe 2lbs at the most. The radiator is definately worth the extra $150 over the S54 radiator. Just thought i'd share the good news. The radiator goes in tomorrow along with lower thermostat, so it will be good to know the cooling system is finally capable of anything i throw at it, definately a good safety measure. anyways i'll keep yall updated.
    Zionsville E36 radiator page
    Very nice!
    I have all of the normal cooling system upgrades but I'm still on my original radiator. I've been thinking about going the aluminum route... Let me know how the install goes.
    Thanks
      Nice i too had great results from that website. except i purchased used parts for my friends 325, parts were great working order and guarenteed. just wanted to share. great site and cheap. post up on how the radiator goes for ya.
        M-Grunt where in So. Cal??
        it is highly recommended to change you radiator after 50K, if it goes it could cost you some serious $$$$. Just changed mine about 3K ago, went with the plastic one. The way I drive my car 6-7K a year was not worth $700.00.
          I'm in the North County of San Diego. I work aboard Camp Pendleton. I get to spend lots of time on the sexy stretch of I-5 between Oceanside and San Clemente... If everybody drives 85mph then I can go how fast????
            Never heard of Zionsville prior to customer buying one for a race E36M3 - thing works very well, is sturdy and should reduce temps significantly.
            Dan Law
            [email protected]
              Can't reducing the temp of your engine have a negative impact on preformace, as the engine needs to be a certain temp to run it's most effecent...
                OEM (Behr?) radiators are less than $200. The aluminum radiator is definitely sweet though.
                  if you ran too low of a thermostat yes it is bad. like the "Racing thermostat" which was 72 degrees was bad for the car, but as long as you run stock thermostat or the 80 degree thermostat from fan delete kit you should be just fine.
                    Ahhh. Thanks.
