looks like it.
[DIY] E36 Underhood Lamp Retrofit (Pics!)
There's a whole retrofit kit for this. I'll have to dig up the part number.
There's also a dedicated engine light switch - http://www.realoem.com/bmw/showparts...61&fg=35&hl=16
Edit: okay, I'm confused by everone's "use the alarm switch" comments, saw you had the dedicated switch
Yes, however, it's far more expensive than just buying the parts separately as I showed in my first post.Originally posted by mmenefeeThere's a whole retrofit kit for this. I'll have to dig up the part number.
For reference, though:
INSTALLING SET ENGINE ROOM LIGHT 63319401943 $15.60 (from Tischer)
WIRING ENGINE ROOM LAMP 61129401873 $34.30 (from Tischer)
That's $49.90, instead of the $14.77 that I spent. I wouldn't pay $50 for this lamp, but I would pay $15.
Just a heads up Jeff... This is not as easy of a Job on the M3 Sedan. The punchout on the heat shielding is on the drivers side and there is no mounting point on the bottom side of the hood at all on either side so you have to create your own bracket out of something. Still a good mod though.
Might want to add that to your original post. And maybe move the drilling step to after you install the light assembly so people don't drill a hole and then realize they can't install.
You're far better prepared than most, I'll give you that.Originally posted by PurduinaM3My engine bay looks great. However, if I'm working on my car at night, I've got either a shop light or two 1000w halogen lights shining down on it, and if I'm stuck on the road I always carry a 4 cell maglite. :shrugs:
This isn't just an emercency light source for roadside emergencies; it's like a little surprise party every time you pop open the hood with the light installed. No car nut should be without one.
If you haven't done it by the time I find my E34 M5 I'll PayPal you the $15. I'll want pictures for my trouble though!Originally posted by PurduinaM3hahaha, maybe when I'm employed and have more money than I can fathom I'll consider it, but until then its just an unnecessary luxury. Cool none the less, but a luxury.
