E36 factory alarm upgrade w/ pics
    E36 alarm light flash option
    Factory e36 95 - 99 alarm systems are made by Alpine and aftermarket alpine alarm system gives you a audioable alert for arming and disarming as well as a light flash.
    Factory bmw alpine alarms do not flash the lights on arm and disarm only if the alarm is triggered.
    I have owned two differant cars and have done this mod to each. I just got a 97 M3 and here is the walk thru. The job takes about 30 -45 min, $8.00 and when you are done and arm the alarm the lights with flash and when you disarm they will as well.
    I am a MECP cert. installer for 17 years and alpine factory trained for alarms (back when they were in production)
    YOU WILL NEED:
    6 - female spade terms(18 ga)
    4 - 6 " wire black, red, blue and white(18 ga)
    1 - 10 amp fuse
    crimpers
    black elec. tape
    zip ties
    phillips screw driver
    olfa knife
    Ok first remove the under dash and locate the brain right about the passenger kick panel. Black 5x8 box with a green connector.
    unplug the green harness and just abouve the fused yellow wire cut the black cover that covers the wire about 3 inches away for the plug end. Just a single slit is fine. pull out the wires.
    now locate the red, dr. green and yellow these are siren(red) lights(grn) and 12v constant(yellow)
    now you need a single pole double throw automotive relay 20 - 30 amp is fine. you can find one at any auto store for $5.00
    wire the relay like this with 6" of wire
    86 to blue
    87 to red fuse this wire with 10 amp fuse
    85 to black
    30 to white
    make a fuse holder with two female spades
    ok now move back to car an attach the following relay wires to car wires(no need for diodes the factory alarm has them internal)
    Relay car
    blue red
    white Green
    red yellow
    black yellow
    after connection plug the main harness back into the brain and test remote and make sure they flash. The car should chirp 4 time due to door being open
    now wrap the harness back up with black tape and zip tie
    install under dash and watch for your friends reaction at night when you arm the alarm ..
    I have many other upgrades i will post later
    if you need help call my cell 706 247 0812
    i will walk you threw
    thanks enjoy SCOTT
    Any ideas why my alarm no longer chirps, even though the remote still controls the locks and I've gone through the chirp on/off procedure countless times?
    Replaced siren with known working - still no chirp
    Checked fuses (except the fuse behind the glovebox) - still no chirp
    Removed factory horns - Maybe this is why it stopped working? although I remember it still working after removal.
      Great info! Let's see your other tricks!
        Good write up
        I'll be doing this once we get our first snow.
          about the no chirps...
          first look at the led when you get in does it light up and then go off.
          and if you arm or lock the car with remote does the led flash
          if not you are stuck in valet mode
          i think the way out is open the driver door push and hold the unlock till the led flashes
          ill check but i think that is correct you can double ck in your manual
          and thanks everyone on the comments
            Nothing. Everything operates as normal (arm - LED blinks).
              Maybe?
              http://www.bimmerwerkz.com/forum/112822-post7.html
                Originally posted by KWorker17
                I'll pull it tonight, but like I said before it was working fine forever.
                Thank you though, will definitely try that!
                  Thats really strange that it stopped working randomly. I know with most alarms there's a way to program the brain, through the keypad, to have the alarm not chirp. I did a search and couldn't find if BMW's keypads have that function. On some remotes, it has directions on the back of the remote on how to turn the chirp off.
                    They do, as stated in the first reply, I already did the on/off procedure countless times. I used the procedure to get it to work in the first place and it worked great for a year.
                      ok have you tested the siren ..
                      hold the lock button for 5 seconds it should go into panic and sound off
                      to stop it hold the lock again then hit unlock
                      or take the plug at siren brown is negative and black w/ blue is 12v. test with speaker wire and a drill battery
                      sirens can get water in them an rust out.
                      any old alpine soft chirp will work or look for one in a junk yard
                        Would you guys find value in me scanning certain pages out of my BMW remote keyless-entry security system owner's manual?
                          Already replaced the siren with a known working one. Still the same.
                          Goes into panic just fine, just no sound at all.
                            ok this is what i would do .. call me 706-247-0812
                            or pull the alarm brain fine the red wire third over from yellow 12v
                            this is the siren out .. alpinr throws a 12 volt out on this wire to charge the siren it is a constant 12 when in panic or alarm
                            ck with test light or just conect the siren positive to it and ground the brn.
                              can you see what it says about the valet feature .. i dont have a manual
                              and how to get it out
                              silene arm/disarm is not what the problem is ..
                              OH but then again you also got to make sure the siren's brn wire has a gound and it is not cut
                              also ck the wire at the siren with a test light..
                              this way you can see if there is a brake between brain and siren
