got my new m3 finally, have lots of questions
    hey guys got my new to me 98 m3 coupe, i will post pics soon, i have a couple question the basics such as
    1) what type of oil do you use? and where do u get it from, i thought it takes 15w 40 castrol synthetic but i cant find it anywhere near me.
    2what tire pressure is recomended?
    thanks for help!
    Search function is your friend
      Congrats on your M3! I use Mobile 1 10w- 30 all year round and for the air pressure I usually have them at 32 psi, but if you look inside your door it will tell you the recommended air pressure. Hope this will help.
        Welcome to da club! Now post pics or
          that's only 2 questions
            oil weight depends on location and local temps really.
            Tire pressures for regular driving I would just follow the values inside the door jam.
              Concur oil depends on location. I assume you didn't get the manual because it is in there. Door jam has the pressures but typically 32 psi all around. I don't run that I run 34 psi. I do run 15W-50 Mobil 1 most the time because I am in Florida so with that heat I prefer a heavier weight...
                I like to run a little bit higher tire pressure, usually around 36-38psi
                Oil weight depends on local weather (temperature). My car is a summer only car and runs 15w40 Royal Purple...
                  Mobil 1 15W50.
                  34 psi all around.
                  Advice for you: start a Money Market account for your M3.
                    welcome to the forum - now we want pics
                      33F / 36R
                      Oil who uses oil? You mean you are supposed to change that stuff? No! I read somewhere it was BMW lifetime fill... (kidding, sarcasm aimed at newbs)
                      In the winter I use 10-40, and in the summer I use 15-50 don't have any issues.
                        Originally posted by Richardsperry
                        33F / 36R
                        Sarcasm from you!? jk Any specific reason you run different front/rear pressures?
                          thnks guys, well i live in southern californi so its pretty hot, since i been reserchin, i m leaning towards 5w 30 oil, 15 40 seems so thick, but i dont know manul says 15w 40 its hard for me to find a synthetic of tht close to me for some reason. so 5w 30 for so cal?
                            Even tire wear and I think it handles better.
                              OP - when you finally post pics of your car, plese change your font size so us older guys can read your posts.
