DIY: Reinforce Your Trunk Latch (Cars with Spoilers!)
    I did this to my m3 a few months ago. This is a DIY for reinforcing the sheetmetal around the trunk latch. This metal gets very weak and can tear, especially if you have a spoiler. I did this because my latch stopped closing, I think it broke because it had lateral forces put on it from flexing in the sheetmetal, I'm not sure though.
    This DIY should take all of 15 minutes.
    1) Go to the best local hardware store around you and find a predrilled piece of aluminum or steel stock. Apparently the holes are a standard spacing, I found my steel stock pre-drilled with the correct holes. If you can't find a pre drilled piece, remove your trunk latch/ actuator mechanism and use it as a template to drill your metal. I
    2) Use Rust-Oleum rust stopper paint in a color that will be discreet (or not) to coat your metal stock. This is more than for looks- if you have steel, it could rust. You do not want to create un-needed rust spots on your car.
    3) Remove your torx screw carefully. I forget the size of the screws, I did have to go get the size- it was not in my torx multi-bit driver.
    4) Align your stock, align the latch, and reinsert and tighten the torx screws. Check for side to side alignment, as well as the angle of engagement to the catch on the bottom. My trunk was very stiff for a couple of closes, now it closes with a comforting thud, I am not worried about my trunk metal ripping anymore at all.
    Thank you fiveightandten for the measurements!
    Originally posted by fiveightandten
    The bolt head are T-30.
    Spacing, center to center, is about 8.6cm. Bolts are M6, so drill your holes accordingly.
    I only have pictures of the finished product, sorry.
    New Pictures:
    On the left side underneath the stock, you can see bowed out and bent sheet metal. This is the beginning of what can turn in to a very annoying problem. It is not rust or anything.
    measurement hole-hole center of spacing?
      I'll get measurements and better pictures tomorrow.
        nice contribution!
          ooo...
          add it to the list of "things to do before end of March
            Yea my original trunk ripped right there...I had it welded, but it wasn't that strong anymore and ripped again. This is a good add
            Though my trunk ripping gave me the incentive to buy a new trunk with the high arch wing
              Do you have the oem spoiler? I was told on these forums that the oem spoiler is a looks only/not so functional piece, so based on that I cant see any issues being caused from down force. More likely just wear of closing the trunk.
                hmm never heard of this problem... lucky for me (or maybe unlucky?) I dont have a spoiler.
                  Lol, its caused by the extra weight of the spoiler slamming it when you close, not extra downforce.
                    Humm. I may do this. I have a heavy replica LTW spoiler on my decklid.
                      ..... and because of the way that sedan lids close they experience thus more fayle.
                      do it now, or get a new trunk lid later, then do it.
                        my bad
                          Good idea.
                            It may be worth noting that the stock bolts have a tapered head to countersink into the sheet metal of the trunk. You may want to just replace them with something with a flat hex head for ease of use.
                              They do not sink as far into the stock as the stock trunk, however the stock I bought actually has countersunk holes drilled on one side. Maybe I should buy all they have left- "custom" paint them, and sell them for $50 each.
