differential
    differential
    cracked differential in a e36 m3 anyone know were i can get a good used 1 for an how much
    OahuMPower is a good source for everything. PM him.
      Did you crack the diff, or just the diff cover? BFC classifieds. Though if it's just the cover, i'd just source a new cover. A brand new one is $100.
        Keep an eye out for auto guys selling 3.38 on bfc, perfect time to throw that in if your diff is in fact cracked.
          finned diff cover. dooo eeeeeet
            LOOOL
              car-part.com
              a diff cover off of a 325/328 will work just as well.
                If it's the cover, go to a salvage yard and take $20 cash with you and a 15mm (I think) socket on a breakover bar.
                  how do the covers crack? when people mistaken the diff for a good jacking point? :/
                    Believe it or not, the differential was a factory recommended jack point on my s2000.
                      It is on a lot of cars...my 2005 WRX included.
                      Just so you don't feel so bad, I cracked my stock diff cover while changing the fluid 5+ years ago. I went to re-tighten the drain plug (without using a torque wrench) and got that terrible feeling in my stomach as the plug suddenly got loose and a crack split the cover from the drain hole to the bottom of the cover.
                      Allowed me a reason to install the RE Finned diff cover, though...
                        Over-torquing the drain/fill plugs will crack it easier than you'd think.
