Teaser: New Carbon Fiber Parts for e36
    Originally posted by das borgen
    I gotta agree with gingermeister here on this...........just because it was offered as an option doesn t make it OK.........i m personally not a big fan of carbon fiber's looks and the OEM pieces do look pretty tacky to me after seeing them LIVE
    I'm not 100% fond of the E36 interior pieces myself, which is why I don't own them. I never said I liked them or not, I just said that BMW pulled it off without being too gaudy. Someone who would mimic those pieces would most likely pull it off OK.
    Not sure when OK became omg excellent... it just meant OK, ie; neat, cool, decent, alright, high five, you win the prize.
    However, you may not of seen a properly done up car. Had you seen Anthony's car in person, the color scheme of every part was bang on and blended the OE Carbon Fiber in perfectly.
      When asked my opinion, I will often suggest less than guys want to wrap. I'm a firm believer in exactly your point above. In a properly done car, the CF should compliment the interior/exterior and too much can overwhelm the car. Did a buddies red M3 with red interior and he got all eight trim pieces done, which looked great, but then wanted the centre console done and that turned out to overwhelm the car and was too much IMO. He loves it though and isn't that actually the goal: to make the car the way you want it and to reflect your (the owner's) vision.....?
        I have something you could wrap for me... it'll take a lot of weave and resin to do the job though.
          next step:
          actually making the parts entirely out of CF. not just a wrap.
              Originally posted by cracky
              next step:
              That's always a consideration, but the chinese are mass producing the main stream parts. I'm focusing on alot of stuff not available through mass production and the main reason I've stayed away from molds so far is that molds are time consuming to produce and are only good for single or light usage and I can wrap faster and I believe with more consistency using my processes. Once you apply vacuum, you have no control over the cloth ansd that's why I see commercial parts with bad weaves; no control over fabric during vacuum process. I "work" the fabric when applying to correct flaws in the weave and ensure the weaves come out straight particularly around corners and bends (where you typically see issues in mass produced pieces). The other more common approach is to change the layout of the part (check for cf molded M3 centre console and you'll see what I mean). They remove as many curves and bends as much as possible to minimize distortion in weave and to make easier to produce; producing in my opinion a part that doesn't following original design and therefore is inferior. By wrapping original pieces, I maintain all the original design and character of the part being wrapped. I think it looks better that way.
              Originally posted by Synenergy52
              [Smilie: Shifty]
              If it's car parts, I'm interested. If it's body parts, the CF will not enhance the grith or impressiveness of your "member".....
                A couple of new pics of some new e36 parts I've decided to wrap:
                  looks good.......but hands down oem ftw. i loved all my pieces
                    Hey, can never go wrong with OE parts, but, I was looking for something different and colours/options that we're available as OE parts. Haven't changed the lines @ at (all OE parts underneath), but have the look I want.... Also, I'm wrapping parts (like the centre console) that aren't available as OE parts!! That's the best part of it. Each part I wrap that's not available elsewhere makes my car more unique, but still carries ALL the original lines that it was designed with.
                    My wrapping is just my way of expressing the way I want my car to look; which unfortunately I can't get from strictly OE parts.
                      could you please provide links ot your wrap materials ?
                        Sure.
                        Resins are from West Systems: http://www.westsystem.com/ss/epoxy-resins-and-hardeners
                        105 resin and 207 special hardener.
                        Cloth is from one of several suppliers. My favourite is CJ Composite Technologies out of California. http://cjcompositestechnology.com/
                        The clear coat is BASF DC92 base and DH42 hardener and UR50 reducer.
                        And there ya go! The materials aren't a big secret. You can multiple brands of resin that will do the job. I've chosen these because of characterstics I like and familiarity with the product now. Others would and have disagreed and suggested other products; but it's a matter of taste and availability too. I have several local suppliers I source the West products through, so inventory is rarely an issue.
                        Similarly with the cloth. There are multiple distributors of CF cloth throughout US and Canada, and I suspect they are all buying from a small handfull of mills or maybe even just 1 or 2 in US as they all introduce the same colours and fabrics within days of each other. Same product; just have a good relationship with these guys....
                        There has never been a secret as to the products I use. They are often quite visible in the DIY pics I post..... the secret to a sucessful wrap is all in the processes employed!! The materials just ensure a good bond and UV protection. I've changed materials several times along the way and currently use both BASF and DuPont clear coats (undecided as to my fav).....
                        Good luck with the wrapping!
                          Finished shifter surround the other night and will be finishing the glove box trim pieces this weekend.
                          Here's the shifter surround:
                            How much did you spend on all the OEM interior stuff? Just curious because your interior was fkn
                              how much would that shifter surround run me? PM with the price if you like
                                That looks well done in the pictar at least.
