Tie-rod part list advise.
    Hi,
    I'm ready to order the tie-rod assembly.
    Is there anything else I should get beside the tie-rod itself for the job?
    Any one-use nuts & bolts I should also order?
    Thanks,
    -GT
    Originally posted by GreenM3/4
    Hi,
    Thanks,
    -GT
    I would like to know too
      You should buy the locking washers for the tierods. Basically, it is a flat washer that you peen over so the nut won't loosen up. Also, you could order new hose clamps for the boots. (I reuse them but I remove them carefully).
      You will also need a pickle fork and a small sledge hammer to remove the tie rod end.
        This. Also an alignment right after, but that is a given.
          I have a set of Lemforder Inner tie rods with lock nuts and locking washers brand new. All I did was take off the outter tie rods when I replaced my whole steering rack.
            wow... this is lacking
            2- FULL Lemforder tie rods (inner/outer) too cheap to not replace as a whole
            2- lock washers
            2- tie rod boots
            2- inner clamps
            2- outer clamps
            2 Tie rod boot 32*21*1*139*786
            1 Left tie rod assembly 32*11*1*139*315
            1 Right tie rod assembly 32*11*1*139*316
            2 Inner tie rod clamp 32*11*1*137*132
            2 Outer tie rod clamp 32*13*1*094*100
            2 Tie rod lock washers 32*11*1*136*526
            your welcome
              OahuMPower,
              Thank you very much for a complete list.
              -GT
                Calvin to the rescue...
                  easy day.. I've got spreadsheets for all this stuff.... just an easy copy/paste
                    2- lock washers
                    2- tie rod boots
                    2- inner clamps
                    2- outer clamps
                    your welcome
                    are boots really necessary? unless its warn out, i think he should be ok with the used ones.
                      dude.. they are like $7... ever try replacing JUST the boots?
                      fcuk... sometimes I wonder
                        Yeah, too cheap not to replace. Do it all and be done with it for a while....
                          2- lock washers
                          2- tie rod boots
                          2- inner clamps
                          2- outer clamps
                          your welcome
                          Wow, exactly what I was looking for
                          Is there a "recommended" DIY for the complete tie-rod replacement for the E36 around? I found a couple without pics and
                          this video
                          , so I have a pretty decent idea of how to tackle the job. However, if there is a great DIY that I haven't found I'd love to see it.
                          Overall this looks like a fairly reasonable DIY
                          I was quoted $349 for parts and labor PER SIDE for INNER tie rods only, which is when I noticed how (relatively) cheap the parts were started searching for DIYs...
                            That nut case went under a car on a cheap Chinese hydraulic jack. Not a good idea. Don't try this at home.
                              Ah yes, his terrible general practices and odd banter aside, at least I got a feel for how the parts fit together
