This weekend was dedicated to replacing RTABs and fixing some little issues. The RTABs went well last night. This morning I started the car and moved it into the garage and everything was fine. Then I proceeded to burp the coolant lines. I began by taking the airbox out to make it a little easier. I then put the airbox back in the car and reset my oil light by jumping the pins. I then began to work on the aux fan. I turned the car on again to see if the fan was working when the ac was turned on. It wasnt. I then jumped the relays and the temperature switch to see if those were the issues. I didn't really come to any conclusions, but I have another thread going about that.
I then button everything back up and go to start the car. I turn the key and the car turns over just like normal then immediately drops in revs and turns off. I try a couple more times and the same outcome. I did give it some revs and it would keep running, but once I let off the throttle it would die. I did try to jump the car just in case it was a simple issue,but same outcome. Any ideas out there? I need some help on this one. Thanks.
