Why me d*mmit!!!
    Why me d*mmit!!!
    I finally had time to work on the bimmer and found out it wasnt getting any fuel to the engine because whoever started the swap crossed the pressure and return line in the engine bay. I uncrossed them and she fired right up! But I have a big problem...
    This is the first time this car has been running and in gear after the swap. I put her in reverse and it moved fine...I put it in first and right when I start to let up on the clutch there was a loud POP noise and the car stalled. I did this three times trying to diagnose the problem but I have nothing. I know it wasnt a backfire because I felt it in the clutch. Can anybody help me? Its a ZF trans.
    I finished the swap and THIS tihs happens to me!!!
    Does the car start?
      it's probably the clutch slave cylinder. It probably burst so check that first. It's fine and not a big deal as long as you can retrieve the plunger.
        Well I just figured out the problem. The previous owner didnt put a diff bolt in. I just fixed it.
          That car sounds like a f ucking gem
            Its a gem covered in dirt.lol
              Ugh, worst ever, I hate having to fix a previous owners screw-ups.
                Eh, that's why its called a project car
