Hello
My dad's vehicle recently had a new folding soft top roof fitted. The person who did it said that a BMW main agent needs to "intitialise" it. When we got the car back from the guy a dodgy idle was evident where it hops up and down. The car was stood for a fair few weeks so thought maybe the car just needs to go on a good run to clear it, but this didn't help.
As the car was going into our local dealer we thought that we may as well let them diagnose it. A couple of days or so later they thought that it could be the VANOS at fault (the VANOS was changed by a local BMW specialist 6 years ago to this month and has only covered 18-20k miles).
I've done a bit of research into symptoms of a dodgy rough idle & VANOS problems etc. Quite a bit points to the Idle Control Valve, Exhaust Advance Solenoid, weak flexi section to exhaust manifold , VANOS seals / o-rings / gaskets etc. Particularly this thread here at PistonHeads
Today, I went to the dealer to find out some more. They took me into the workshop where the technician (senior, apparently) said that he thinks it's a timing issue. I wish I took a photo of the state of dismantle the engine bay was in (I might do tomorrow when I go to test drive an i8). The cam shaft(s) were exposed, but the silver VANOS covers seemed to be untouched. The technician used some instrument which was inserted into a hole in the block to demonstrate to me that on one side it was flush, but when he rotated the instrument it wasn't flush. I don't know if what he showed me had any significance to the problem nor whether he was fobbing me off. I can be cynical with ANYONE in the motor trade.
Later today the service advisor called me and left a voicemail message telling me that he has spoken further with the technician etc and that they believe there are two options now left on the vehicle.
Option 1 - adjust timing, rebuild vehicle and test it. It may be that that solves the problem but then again it may be that it needs the "VANOS transmission unit" replacing afterwards. £1,340.39!! including VAT (this figure already includes oil service @ £173), investigation, timing check)
Option 2 - replace VANOS transmission unit and adjust timing (he said that the timing has to be adjusted when the transmission unit is replaced, that's why including both. This quote £3,168.37 including the VAT!!!
I have a call recording app on my phone (ultra useful) so will upload the 01m:47s recording to Dropbox, share it and provide the link below. I think it might be useful to listen to the guy's tone of voice and for feedback to be provided.
https://www.dropbox.com/s/5ml6681xmv...22222.AMR?dl=0
Can anyone help or advise with a) against what the dealer is saying and b) advice re. the dodgy idle, please?
