That's a quick fix, not bad for those of us who run without an airbag.
I was thinking of making a "racing" wheel type adapter, but for stock wheels. It would consist of 3 parts; a column side hub, a replaceable tube, and a wheel side hub. The column mating side would have all the mounting for the OEM slipring. The tube would allow you to set the length (by means of ordering the size(s) you want) and carry the extension wires up to the wheel.
I need to learn solidworks
Can probably get one of my engineers to sketch it up for you (if you got a rough idea of how you want it to look). Got a 3D printer on-site also (validate fitment, etc)
I'm not much of an artist, but I'll see what I can do!
Regarding the topic, what about (trying) to get a manual tilt+telescoping steering column from say an E38/E39.
Will probably require welding and stuff, but it will allow for all OEM controls, steering wheels and working airbags.
Years ago I wanted an electically adjustable column and bought a telescoping+tilting one from an E32. But it was all but plug and play and I ditched the idea.
They're the electric adj seats. I've cut a spacer on the rear rail down to where the elec motor is against the floor. So, w/o significant changes, I'm as low as can go. Yes, I could prob get another 1/2" back with additional mods, but at some point I should just buy aftermarket seat/rails.
Any chance that you took pictures of those modifications, or could potentially take a few that show what you did? One of my big issues with my current seats is the electric not going as low as the manual. When I had a 95 with manuals I didn't have a problem finding a good position. I had one of the tilt adjustable ones, but still wanted the wheel closer.
I like Braymond's suggestion, which I couldn't find with a 2 minute google search, so it obviously doesn't exist.
The other way I can think of is to use a donor steering wheel and cut the metal part out of the back, then weld it to the good wheel with spacer/gussets that provide whatever offset that you think will work for you. Then you could source longer bolts, where necessary, to bolt everything back together as if it was a normal wheel.
I did not read all the pages but I had a 93 325is with a tilt steering wheel, guess they are not common and wished I had pulled it when I stripped the car but I was moving so I only took things I needed and could pull rapidly.
Just an FYI, I have a tilt on my Canadian 1998 M3. One of the few differences between Canadian and American cars.
I agree with the previous comments that tilt is a lot less valuable than telescoping. The lack of telescoping is one of the things that bugs me about my car
While I'd like a telescoping function as well, for me the tilt function is just as valuable.
Range might not be too much, but makes all the difference between a good and bad position.
I have the seat on the lowest setting, with the steering wheel all the way up (not sure if all up or all down is the position for non-tilting wheels) it's too high. But with it all the way down, I can't get in or out. So it's always up when I'm out of the car, then when I take a seat, first thing I do is put it all the way down.
Tilt is not a problem for me. when I had the 95 with tilt, I ended up with it set in the highest position, which is the same as the fixed position that we ended up with over here.
Like everybody has said, I would like my seat lower, and the wheel to be 2"-3" farther out.
For the data point, I am 6'0" but I have a long torso for my height, which makes me have to recline more than I would like to clear the roof. I haven't even tried to wear a helmet in this one yet. That recline pushes my shoulders farther from the wheel which then makes me have to keep the seat closer, which then pushes my knees into the bottom of the steering wheel. So first world problems...
Good to know. So without tilt the wheel would be too high for me.
I'm 6'3.5" seat at the bottom and relatively long legs.
So when my legs are comfortable, reach is too long, with good reach, my knees are folded behind my neck. So wheel that could telescope further towards me would be ideal.
But after 11+ years of daily driving an E36 I got usef to it.
I did look into retrofitting a tilt-telescopinh electric column out of an e31/e32 but requiers welding and modding so I ditched the idea.
USA's not so bright DOT deemed it unsafe (say what!?) and the option was dropped on later production.
While over here in Euroland it was standard equipment.
There are many DOT complaints to be made, but pulling the tilt column because the E36 did so poorly in crash tests seems like a BMW failure, not a regulatory one.
My Dad has a '94 325i that he bought new. I remember that even with the fixed steering column, it was still recalled to better secure it.
