Lately, I've been reading a lot about whether a thicker rear sway bar is needed for the performance enhancement of the E36 M3. The consensus seems to show the following:
1. Consider all other adjustments and suspension fine tuning before actually installing aftermarket sway bars.
2. A bigger front sway bar corrects the understeering nature of the E36. This effective is counter intuitive and opposite of the what a larger front sway bar does to other cars.
3. The rear sway bar can be deleted, provided that the rear springs are stiff enough to reduce the body roll.
4. Installing a bigger rear sway bar requires reinforcing the sway bar mounting tabs.
As of now, my car has the following suspension components:
Vorshlag camber plates
AST4100 coilovers
Hyperco 450lb front and 550lb rear springs
225/40/18 and 255/35/18 tires (36psi all around)
Eibach 26mm front sway bar
Stock rear sway bar
The 450/550lb spring combination is really the harshest setting I would like for now. As it is, the car has a very neutral handling characteristic, maybe a very slight understeer when it's pushed hard. Body roll is not terrible.
The question is, should I go with a bigger rear sway bar to help the car handle better for street driving (and occasional canyon runs)?
Eibach makes two types of rear sway bar for the E36. The 24mm for the M3 and the 21mm for the standard E36. Which of these is a better choice?
Will I compromise the performance of my suspension setup with a larger rear bar?
I would hate to have a tail happy E36 but wouldn't mind having a sharper turning rear end in case I take the car to an autocross event.
Any opinions?
Thanks in advance.
Jon
AST4100 coilovers
Stock rear sway bar
Any opinions?
Thanks in advance.
Jon
