98 M3 with 168,000 kms (105,000 miles)
recently bought the car - did not have maintenance history with it - recently replace the oil and used 5W/40 synthetic liquimoly oil
oil light comes on when idle after long drives (engine hot) and the light goes away when I tough the gas.
The car came with aftermarket gauges. When cold, the oil pressure reads 10psi - as the car gets hot, it goes down almost a half point which could mean 5 psi or less - and when accelerating, it is @ 55 psi whether hot or cold
I had done some reading into this - and there are too many theories out there
Has anyone had this issue and it went away by simply replacing the oil pressure switch? or is it too simple to be true?
