Looks like my oil pan gasket started leaking the other day, annoyingly. So I'm going to start work on replacing it within the next week or two, depending on my schedule.
I've done a ton of searching and reading up but still want to make sure I get through all the "while you're in there" items.
Because the subframe needs to be dropped and because my tie rod ends are pretty worn, I'm going to replace the full tie rods (and swaybar end links, which also have no more rubber). I've already replaced all the PS hoses to fix that system's prior leak.
I'll also replace the dipstick o-ring, which should be easy. I know the oil pump nut is a potential issue, but I'm not going to drill/safety wire it and I'm not going to weld it. If it's still tight, perhaps I'll just damage the threads with a punch and a hammer as a basic precaution.
What else would be good to tackle?
I probably need a new engine drive belt, but I also want to replace the tensioners and the water pump, but honestly, that all is going to wait until next winter (I just replaced everything else cooling system, don't want to drain and refill it yet again right now).
thanks in advance
thanks in advance
