My 99' Hellrot intro
    Looking good!
    There were 5 Hellrot/Magma coupes produced during the last month of production. EY83900 is the last one off the line in that combo. What's odd is that all 5 build sheets show a sunroof.
      As I've said many times, you can 'Plump-n-Swap' those seat cushions. Then you wear the other sides of the seats. Swap passenger and driver seat cushions. They are the same.
      No amount of fancy leather treatment is going will restore worn leather. You can sometimes find a beat set of Magma seats. Then steal the passenger cushions.
        congrats.......I recall when I bought mine back in 2005. 1999 hellrot with magma interior
          nice car..
          get rid of the back euro-plates. its hideous.
            Nice man. I have the same combo
              Very nice looking car. Hellrot over Magma is a killer combination
                Let me know if you ever want to sell
                  Thanks everyone
                  Originally posted by MMMGP
                  Looking good!
                  Was April the final build month, or May? Mine is 4/99
                  Awesome, good to know... Like I said before, I'm fine with the wear (maybe I'm weird) but I think it actually looks cool. Just don't want it to get worse...
                  Originally posted by ZiMMie
                  nice car..
                  These are the original export plates (why they are red instead of blue) from the first owner's European delivery, these are a part of the car's story so I'm keeping them.
                    One question though regarding seats... The driver's side seat has a bit of creaking and moaning in it. Also, I just discovered it won't recline. Is there a way to rebuild the guts of the seats, or is this more like a swap them out kind of case?
                      The final build month was May, but only 2 coupes were built that month.
                      EY83963 5/4/99 TITANSILBER METALLIC (354) TEILLEDER W.N./SCHWARZ (N5SW)
                      EY83747 5/7/99 DAKARGELB 2 (337) TEILLEDER W.N./SCHWARZ (N5SW)
                      There were 5 Hellrot/Magma coupes built in April of 1999, but each one lists a sunroof in the build sheet. Wondering if the build-sheet database has an error, or if the PO of your car deleted the sunroof.
                      EY83479 4/15/99 HELLROT (314) TEILLEDER W.N./MAGMA (N5AX)
                      EY83488 4/15/99 HELLROT (314) TEILLEDER W.N./MAGMA (N5AX)
                      EY83560 4/17/99 HELLROT (314) TEILLEDER W.N./MAGMA (N5AX)
                      EY83664 4/20/99 HELLROT (314) TEILLEDER W.N./MAGMA (N5AX)
                      EY83900 4/26/99 HELLROT (314) TEILLEDER W.N./MAGMA (N5AX)
                        If you have not already, use a vin decoder and type in the last 7 of your VIN, it will give you exact build date and all your options. www.bmwvin.com
                        MMMGP is the resident expert on production numbers & build stats. Much of what we know here is due to his research and leg work.
                        April 29 was the last mass production day for US Spec E36 M3 coupes. For some reason though, the sequential VIN's may not be totally indicative of actual build order. The last sequential VIN is EY84011....but shows a 4/28 build date. Oddly though, (3) numbers before it, EY84008 shows a 4/29 build
                        Simplified, EY84002 (my car) shows 4/28 and EY84001 shows 4/29...both are the exact same color combo, but apparently not built next to one another. One step further, who is to say that EY84008 (highest # on 4/29) was the actually the last car made and not 3974 (lowest # on 4/29). Who really knows what order these cars came off if they were already out of order with the 28/29th splits.
                        It's obvious I researched this subject quite a bit (maybe too much). I did most of it as I was buying my car, and I'd be lying if I said it didn't have an effect on my purchase decision (it was not my sole decision maker, as the car came with tons of records and was well sorted). My opinion is that I don't think anyone really knows (as 100% fact) what order the final ones came out in. The only verifiable fact is that there are 9 VINs higher than mine....so that's what I go with. I did go crazy with Autocheck...of the 9 higher numbers, I think 4 were off the road or salvaged.
                        **Also worth note that VINs 3963 and 3747 show random build dates in May. Not sure what that was about or if it's accurate seeing as though they are way out of order.
                          Looking good!
                          Possible swapped interior?
                            With 122k it is unlikely that the vanos does not need done. It makes a distinct rattle that can be found on YouTube. If it is due for refreshing Beisan Systems or DrVanos are where to go. These cars have hydraulic lifters that do not need adjusted. Nice car..
                              Yea to be honest, I did not look into the production date or anything like that when buying the car at all. The paint on the roof is definitely original, as is the interior.
                              This is what that site shows me when I enter my VIN. Interestingly enough, my VIN is not among those listed above as being made in April of 1999 but it says right here, production date April 26th 1999. For the sake of posterity please add this info into your database. I trust no one will do anything weird with my VIN
                              Vehicle information
                              VIN long WBSBG9336XEY83834
                              Type code BG93
                              Type M3 (USA)
                              Dev. series E36 (2)
                              Line 3
                              Body type COUPE
                              Steering LL
                              Door count 2
                              Engine S52
                              Cubical capacity 3.20
                              Power 179
                              Transmision HECK
                              Gearbox MECH
                              Colour HELLROT (314)
                              Upholstery TEILLEDER W.N./BEIGE E36 SANDBEIGE (N5SN)
                              Prod. date 1999-04-26
                              Order options
                              No. Description
                              243 AIRBAG FOR FRONT PASSENGER
                              260 SIDE AIRBAG DRIVER/FRT PASSENGER
                              428 WARNING TRIANGLE
                              473 ARMREST, FRONT
                              498 HEADRESTS IN REAR, MECHANIC. ADJUSTABLE
                              534 AUTOMATIC AIR CONDITIONING
                              540 CRUISE CONTROL
                              676 HIFI LOUDSPEAKER SYSTEM
                              686 DIVERSITY-FUNCTION AERIAL
                              692 CD CHANGER I-BUS PREPARATION
                              781 M LT/ALY WHEELS CONTOUR
                              985 US RADIO SUPPLEMENT SET
                              Series options
                              No. Description
                              209 LIMITED SLIP DIFFERENTIAL (25%)
                              214 AUTOMATIC STABILITY CONTROL+TRACTION
                              314 HEATED WINDSCREEN WASHER NOZZLES
                              354 GREEN STRIPE WINDSCREEN
                              410 WINDOW LIFTS, ELECTRIC AT FRONT
                              441 SMOKERS PACKAGE
                              465 THROUGH-LOAD SYSTEM
                              520 FOGLIGHTS
                              542 CHECK CONTROL
                              556 EXTERIOR TEMPERATURE DISPLAY
                              687 RADIO PREPARATION
                              710 M LEATHER STEERING WHEEL
                              785 WHITE DIRECTION INDICATOR LIGHTS
                              850 ADD FUEL TANK FILLING FOR EXPORT
                              853 LANGUAGE VERSION ENGLISH
                              992 NUMBER PLATE ATTACHEMENT MANAGEMENT
                              All of this makes perfect sense aside from the "white direction indicator lights" which I can venture to guess were replaced with amber after the accident, along with the new headlights, foglights, bumper, rad, etc...
                                PS: super noob question... 15w50 is the preferred oil weight for this car... Right? For LA County weather. Just wanna make sure I have that right.
