KW V1 Adjustable perch location?
    Ok guys, I picked up some KW V1s, used, and as I was installing them, I am now second guessing where the rear adjustable perch goes. I have always put them on the bottom, but you can't adjust them from down there in this car. Do these go on the top vs bottom? Anyone have some that can provide some advice? Unfortunately I didn't get any instructions and in a quick search I found pics both ways. Thanks in advance.
    I'll look under my car when I'm done my pizza and have an answer for you. Pretty sure mine are on the top.
      Great, thank you. Seems odd on top, so let me know. Because they can't be adjusted on bottom, I think that may be what it is. Good thing I only did 1 side so far , assuming you come back with that answer. Get eatin....
        Yep. They are on top.
          And you have V1s?
            Yep.
            Untitled by Chris West, on Flickr
              Thank you.
                I have my TC Kline adjusters on top. You're fine.
                  This is my 1 big pet peeve with the PSS9's. The perches sit inside the rear wishbone, making them impossible to adjust in situ.
                  The only thing going for it, is that they are bolted to the arm. On top it just sits between spring and chassis.
                  By the looks of it, in theory, the PSS9 perches could be fitted like this also.
