First of im 17 and when i graduate highschool im going to buy a us spec m3 (97-99) and i wanted it to be a track car and withstand 800-1000 hp now it sounds crazy for a 17 year old to have a 1000hp car but these are plans for in the future when im much more mature when it comes to driving and after ive had tons of track lessons. For now i want to save up and do mods that dont necessarily add power but can prepare the car for 800-1000hp, Money isnt a problem for this build but i want to know what mods it will take to have a 800-1000 hp m3 and what mods i should do first.
here are the mods i already have planned but i am unsure as to which brands are the best and what other mods i should or shouldnt do
Turner Motorsport Adjustable Front Sway Bar End Links
Turner Motorsport Oil Cooler Kit - Stage 2 With Euro Oil Cooler
E36 M3 Euro Oil Filter Housing - Modified By Turner Motorsport For Use On US Cars
Front Adjustable Camber/Caster Plates - E36, Z3 - Turner Motorsport Track
Turner Motorsport Rear Trailing Arm Bushing Limiter Kit (RTAB Shim Kit)
E36 M3 US Supersprint Performance Muffler
Turner Front Aluminum Strut Brace - E36 323i/Is 325i/Is, 328i/Is, M3
E36 325i/328i/M3 Turner Motorsport Front/Rear 30/24 Sway Bar Upgrade
Active Autowerke Supercharger Kit - (Rotrex) - E36 M3 (400hp kit)
E36 X-Brace Reinforcement turner motorsport
M50 Manifold Conversion Adapter Kit (To Install OBDI Manifold On An M52/S52)
E36 (Incl M3) Stainless Steel Brake Line Set - DOT Approved turner motorsport
Turner Motorsport Power Pulley Kit - E36 325/M3, E34 525i (M50), MZ3 (S52)
E36 PWR 42mm Aluminum Radiator Upgrade
Supertech BMW M50, M52, S50, S52, M54 Valve Kit Severe Duty Turbo Or Supercharged - 24 pieces
AutoPower 6Point Bolt in Roll Cage BMW E36 M3
ACPT Carbon Fiber Driveshaft BMW E36 M3 96-99
CP-Carrillo Forged Piston Set
E36 Fuel Starvation Kit bimmerworld
aFe Intake Kit for BMW E36 M3, 328i, 328is, 325i, 325is & 323is
Bilstein Clubsport Front & Rear - 48-215855 - E36 M3
VAC E36 Big Bore/Large Diameter Performance Throttle Body
Pauter Connecting Rods - S50/ S52
Bosch 24lb Fuel Injector Set
USB Conforti Shark Injector Engine Software - E36 M3 (OBDII)
Epic Motorsports M50 High Lift Race Spring Kit
Epic Motorsports E36 M3 Sport Camshaft Set
36 OBD2 Dual Pickup Oil Pan/Pump Upgrade
Clutch Masters Steel Flywheel - FW-140-SF
Clutch Masters 850 Twin Disc Clutch Kit - 03005-TD8S-A
ZF 5-Speed Race Prepared Transmission
Cusco - Hybrid Limited-Slip Differential
i excluded all the other mods like carbon wing splitter seats etc
This is my first using time these forums so im glad to be here and plan on using them more often
opcorn:
