Not another US Spec M3 revival/Track build
    Hey all,
    Been a while, flip flopped cars some and got back into yet another e36 m3. What's different about this one? Well it's green, which I've never had a green on so that's a plus. Also it's a 1 owner Florida car with maintenance records. High milage but compression is perfect. So enough of the pleasantries and down to business !
    1997 M3 5mt
    Unmolested till I got her but she needs it!
    Plans
    Replace trashed parts so I can dd during winter instead of using my baby (135i 6mt :^) )
    Poly as much as I can
    RTABs revshift
    Replace powersteering lines
    Flex disc
    Brakes (steel branded lines and so on)
    Shocks and shock mounts
    Control arms rears and fronts
    Motor mounts poly revshift
    CAI
    Coolant system inspect and update as needed
    Square 8.5 contours
    Stance coilovers (come springs)
    X brace
    Replace seats
    Strut braces
    Chassis reinforcement
    And I'm sure I will be updating as time goes on. Owner got to old to take care of her so I'm anticipating replacing anything rubber under the car.
    Parts
    And progress!
    Prepping it for driving most the fancy suspension bits are going on after winter!
    Got the seats out, and cleaning interior for new seats.
    Almost everything rubber seems to be in this shape
    Oem replacement for time being
    Also started dropping the RTA so pics soon!
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Do you records of a cooling system replacement? I would replace the ENTIRE cooling system and all rubber vacuum lines, manifold gaskets while doing so. Definitely needs to be tip-top for track work. I love the green!
      Yes I do however I may pull the pump anyways and check to see if metal or plastic.
        Okay so been working on the car and here is what's done
        Here are the new seats, I know not Vaders but minty e36 ones regardless
        Also got driver side RTAB done and installed that tool made it so much easier!
        Old bushing was bad big time
        Perfect fit more soon!
          I'm just behind you on the refresh process with my '98.
          Very nice stuff!
          I'll be following this thread.
            Thanks the car is really easy to work on which is a breath of fresh air!
              make sure you grease the living hell out of that RTAB. especially the metal dowel, there should be groves in the poly where it sits and they need to be packed with grease. When i did mine the one side would creak like crazy until i repacked it.
                Yeah I greased the he'll out of it lol where grease was coming out between the metal and bushing
                  excellent. keep up the good work!
                    Have you dropped the transmission yet?
                    I just ordered a 20" extension to get the starter and ***** bolt at the top of the trans. Talk about annoying.
                      Never dropped one alone, always pulled everything out at once. But good luck with that. Keep me posted as well since I may do the clutch soon.
                        Pulling the trans really isn't hard on these if you have the right tools
                          Congratulations! Its a very nice M3. Enjoy in good health.
                          Always a pleasure to know people who work on their cars.
                            Bravo!! Boston Green is a real treat. I keep getting family pressure to sell mine but I know I won't find another.
                            Here's my thread.
                            http://www.m3forum.net/m3forum/showthread.php?t=444649
                            Those were clearly not the original LUX seats. Per the color of the carpet, I'm guessing that was a Magma interior. Not easy to find.
                            Look at the build-sheet under the back seat. It'll define the car, obviously.
                            If you can give us the VIN, we can confirm it here too. https://www.bmwvin.com/
                            Original cars are valuable cars, in general. Modded/molested cars are good for parts, sometimes.
                              Here's my thread.
                              Yeah she had the tans with the m stripes in her but they are horrid. I'm put them up to get redone, and I'm keeping all the oem stuff I take off. As of right now she's going for a functional revival. I want performance and reliability and after having 8 I finally got it somewhat figured out. Hard to balance.. don't get rid of it man she's a beautiful car. I'll sub to yours as well. I may have my cousin do the motor mounts and powersteering lines since he has a lift.
