I replaced my headliner this weekend and when doing so, investigated why the light is always on with my sunroof switch. My car drains the battery after a couple weeks of sitting and I'm trying to identify battery drains and realized this shouldn't be on the entire time the car sits. Also, I have a 1998, and should have the one touch sunroof and don't. So, I took off the sunroof switch plate and this is what I see. I need to get a wiring diagram and figure out why this is like it is, and get it back to normal, but wanted to see if any of you on here knew the correct part number for the one touch switch. I'm also going to need the plastic switch housing as mine was cracked by the previous owner. Thanks to anyone with advice on this. I think the P.O was trying to make the switch hot all the time instead of just with the key on which is how I assume it should be.
Mine is a '97 sedan... Looks nothing like your wiring...
