Hello M3F,
For starters, this was a preventative cooling system refresher on my VF supercharged 88k mile 1995 M3. I changed everything from radiator to a new Stewart pump. The only non-OE (BMW logo on most parts) is the radiator itself (Behr OEM Z3M) and the Stewart pump. I even bought a new fan clutch and fan blade.
Now I've raised the nose of the car and pressure filled the cooling system with the Schwaben tool advertised all over ECS. As I filled it as per the YouTube video, I noticed after letting it idle for 13-15 minutes that the needle starts moving past the center point. I understand that the dash gauge is a dummy gauge so I immediately turn off the car.
1) My heat isn't warm. It was very hot before. (Yes I put the fan on position one and set heat to maximum both times while draining and filling the system.)
2) On my last 1995 with 47k miles, when I replaced all cooling system (again as preventative maintenance) I did the ghetto bleed aka raise the nose up of the car and let the car air burp itself and it worked. Should I be doing that as well?
Thank you all for taking your time to read this. Very much appreciated.
