I've been inspecting my newly acquired coupe for rust, and I found two minor areas that I suspect are the result of a previous owner running larger wheels/tires with a lowered suspension. One area is on the inner lip of a rear quarter panel near the point where it meets the rear bumper, and the other is on the inner rear wheel well, which appears that it may have at one point been trimmed to address a rubbing issue.
The inner lip of the rear quarter panel is the area I'm most concerned about. Using a dremel to sand it down and remove the rust like an easy solution, but I don't want to create too much heat and damage the painted side of the quarter panel. Perhaps I should sand it by hand?
On the wheel wheel rust, I'm thinking dremel or drill with a wirebrush attachment, and then seal it.
Any other suggestions?
