I recently purchased a 1997 m3 with around 63k miles on the car and it misfires in cylinder 6 and sometimes cylinder 5. When the car is cold it doesn't misfire but when it gets warmed up it starts misfiring. Also when I'm driving the car it doesn't misfire only at idle. I have swapped out the spark plugs, coils, injectors, cleaned the idle control valve, checked for any vac leaks, swapped out the man from a working 97 m3, did a compression test and all cylinders were good. Im wondering if I'm missing anything else before I rip up the engine and check the head.
P.S the car was sitting for around 6 years, the owner said he replaced the fuel pump and filter but maybe he could have made that up. I might check to see if the car is getting enough fuel this weekend. If anyone else has some other ideas that I haven't tried please let me know. I really doubt that its the head because it doesn't show any symptoms but maybe a bent valve? Maybe camshaft position sensor?
Let me know what you guys think, thanks.
