Hello all,
I have a 1999 e36 M3. The previous owner performed various cooling upgrades which included replacing the stock radiator with an aftermarket aluminum radiator. I have had several issues with this radiator. When I bought the car the previous owner had also taken the fan off as well. I sit in traffic sometimes and I didn't want the car to overheat so I installed a new fan. I had to pull the fan shroud out a little bit to help fit the fan and so I had to disconnect the hoses on the top of the radiator to create more room to get a wrench in there as well.
I discovered as I was assembling the hoses back on the radiator that the outlet to the engine and the outlet to the overflow tank are so close together that I cannot fit both hoses on with hose clamps. The hose clamp for the outlet to the engine is essentially sitting on the flange that is was supposed to sit in front of if that makes sense. This is because there is not enough room between the 2 outlets for both hoses and both hose clamps.
Eventually I developed a small leak on the outlet hose to the coolant overflow tank because I probably punctured it with a screw driver trying to push the hose camp all the way on.
A month ago it developed a full on blow out on the highway. Car overheated slightly but only for like 10 seconds as I got it off the road. I had it towed home and it has been sitting in my garage. I am now in a position to work on it again.
I was wondering if anybody else had any problems similar to this. I seem to be the only one. My potential solution is to pull the radiator completely and have someone professionally weld an AN fitting to the outlet to the overflow tank. Does anyone have any thoughts? Also the coolant dumped all over my alternator and now the battery wont charge so I have to replace that as well. Although the alternator may have been on its way out anyway. Does anybody here rebuild theirs? or should I just purchase a new one?
Let me know if you need any clarification on what I am trying to describe.
Any help or opinion is appreciated.
