The other day I was backing out of my parking spot and noticed that there was a slight thump on the passenger side as the wheel makes the revolution as if a bearing tooth were missing...so I investigated yesterday. I discovered I had a leak by the output seal on the passenger side so, I searched the forum then, jack up the car and turn the wheel while I placed the uncomfortable mechanic stethoscope to listen...couldn't hear anything. Then, I wondered whether it's uneven surface of the apartment parking lot.
Now, my research revealed some refill the differential with 75w90 and add the Corvette limited slip additive; however, when I check Pelican to source parts, all they had were the 75w140...is that the new acceptable fluid?
Also, I wanted to replace the seal without dropping the differential; however, this diagram suggests that there's a lock ring at the end...research results wasn't clear on whether I can pull out the drive flange after disconnection to change the seal. This will be my first time working on any differential...so any tips are welcome.
Differential from the passenger side
the underside of differential
The drip overnight
The drip overnight
