2 year update on bluetooth mod into C33 head unit
    Hey everyone - I originally wanted to make this vid to help out the new owner of my '97 m3 before it shipped off - then figured someone else might want to see how this custom install works.
    Hopefully it helps someone who was in my position a couple years ago - basically searching every thread on multiple forums looking for a reasonable bluetooth audio streaming solution while maintaining the stock appearance.
    YouTube (Short URL)
    cool mod - I've been thinking of going back to a stock looking setup for a while.
    found this in your youtube description, this is the outfit that does the mods?
    http://factoryradioservice.com/
      I need this. This is much better then a unit plugged into your cigarette light port.
        Get a stock unit with CDC connector and you don't need modding and gives you option to connect an interface with all modern options.
          yup...i paid ~$125 so factor in a bit of inflation
            I've had this mod but done by George over 2 years ago (forget his name on M3F). His setup takes over the center cassette tray entirely. There are buttons to pause and play and the quality is CD level. I also have a mic fitted which helps with conference calls and such when I'm on the road. It has saved me from multiple tickets. Although I have to speak up. I do believe your mic can be located overhead. right above your visor.
