Hey, Geoby here. New thread for my car, and for letting y’all know my situation and some questions I have.
Background:
For those who may not know me I’m 17 years old and have just recently purchased a 205,000 mile, e36 m3 sedan for 4500 dollars. Pulls strong and engine, trans and pretty much the whole car seems to be very strong and is holding up very well ATM. I’ll explain my situation. I won’t have any college expenses, and am a senior in high school as of now. I decided to buy the car I bought not solely because of the low purchase price but because of the relatively good maintenance records, good seller and the need for some work to be done to it. I’m going into mechanical engineering and am planning on taking videos of all the work that I do and posting it on YouTube, with the intention of maybe using the channel to offer another dimension to my application when I apply for internships. I have about 5 months to get the car to where I want it to be- if not close. I have about 4 thousand left over for parts, and a decently paying part time job. I also have a dead reliable spare Honda Odyssey at home if/ when my m3 is out of commission. By no means am I trying to dump all my money into the car, but I am trying to keep it in good shape, and am willing to spend money to do so.
Now my plans for the car:
I want to keep it for as long as I can as a street car. To do so, I want the car to last, and am ready to take the necessary steps to try and make that possible. I searched around a couple forums and found some information on which parts to replace for high mileage cars but not enough to my liking. If anyone knows of any other threads I should read, please link them below and I will gladly give them a read. I've read almost every e36 thread on here pertaining to my situation, and am now reading through member journals to try and get some more info- and because they are pretty entertaining.
A quick history on the car: owned by an enthusiast for the first 100k miles, who traded it in for an m5. Second owner owned it for the last 100k miles and did the following to it: (records attached below/came with a stack of reciepts)
He also included a trunk full of parts(pic below)
I had a PPI done on it and these were the issues and part #’s(In order from most urgent to least urgent)(Not all will be addressed immediately- some were just nitpicked and will probably be done a little later down the road)
Issue-Part Numbers- Part Name
Belts and Tensioners Cracked-11287841228(Idler Pulley);11281748131(Hydraulic Alternator Belt Tensioner Roller); 6PK1555(BMW Accessory Drive Belt)
Intake Camshaft Position Sensor Faulty- 12147830789-PO replaced a year ago due to a CEL light that came on/off periodically. He said it came on for him under 60 degrees but it comes on/ off for me randomly seemingly unrelated to the temperature. Advice needed!
Transmission Shift Shaft Seal/Output shaft seal leaking-23128677736(Selector Shaft Seal);23111224799(Output Shaft Seal);30504(Trans Fluid)
Power Steering Pump to Rack Line leaking-32411141953(Power Steering Pressure Hose);29934(Power Steering Fluid)
Power Steering Pressure Line leaking- 32412228284(Power Steering Return Hose);29934(Power Steering Fluid)
Power Steering Pump to Reservoir Line leaking-29934(More Power Steering Fluid)
Faulty Charcoal Canister-might order a used one but i've read it doesn't really affect the car if faulty- just emissions; advice?
Valve Cover Gasket Leaking- 11120034108(Valve Cover Gasket Set);11121437395(Valve Cover Seal Washer)
Oil Pan Gasket Leaking-11131437237(Oil Pan Gasket);11427833769(Oil Filter Kit);102784(Oil)
Engine Oil Vanos Line Leaking- 11361703464(VANOS Oil Line);RCS14X18(Copper Crush Washer- 14mm)
PCV System Failing and seeping oil-11151740393(Engine Oil Separator Hose);11151703775(Oil Separator Hose);11151703484(Crankcase Pressure Regulator Valve)
RTABS Worn- OEM RTABS with limiters
Resonator Rubber Clamps broken- 18301703634(Exhaust Hanger-included in trunk)
Engine Fan Clutch has slight play-11527505302(Radiator Fan Clutch)
Drivers Side Door Lock Actuator is finicky(sometimes works sometimes doesn’t)- seller included new actuator in trunk
Possible Rear Main Seal Leak- 11142249533(Rear Crankshaft Seal)
PPI.was done by Eurowise in Charlotte, NC.Not sure if sourcing a used camshaft sensor and charcoal canister are good ideas, but feedback would be great. Also I’ve been told to always use OEM parts but are there any other quality brands out there that’ll cost me less?
The owner said I should probably have these done in the next 6-12 months: Radiator, Water Pump, Expansion Tank, Front right koni yellow (PO said it's getting a little less stiff-front left replaced 30k mi ago and remaining 3 were repacked at 165k), and rebuilding the shifter linkage
Other than the ones listed above, I want to address the following: Oxygen Sensor, Replace all fluids, clean MAF, RSM’s, RSM Reinforcement Plates, And any other preventative maintenance items I can do
And not sure if I should do these yet but: Front and rear wheel bearings, Ball joints, Control Arms, rtab pocket reinforcements,front strut mount reinforcements, rear camber arm reinforcements, etc.
I got some simply green degreaser and will be putting the car up on some ramps or jacking it up and cleaning all the grime off the engine/hoses so I can get a baseline and see what is actually leaking and how much/is it even worth messing with- the PO sent me pictures of the leaks and i've checked most of them out and all of them are very minor/ close to nothing so I don't foresee too much money going into that.
So, with all these repairs, and keeping the car as long as possible in mind, are there any other "when we're in there" jobs I can do while doing the above? I wanted to get some feedback before i ordered the parts in case I could get a better deal on a kit or something- I want to use quality parts and do a quality job but I also want to do it cost effectively.
Overall, the car has a ton of chips and minor scratches but I’m not interested in the cosmetics, rather the mechanics. Only after I get it as close to mechanically perfect as possible do I plan on modding/ “beautifying” the car( as my dad puts it). Now, I want to do everything in my power to keep this going as long as I can, and while I know there are some inevitables I’m still ready to do as much as i can to keep it going, I realize situations change, but as of right now this is mine. Any and all feedback is appreciated and again if anyone has any information to high mileage m3s, or any advice at all it would be greatly appreciated and noted.
And also, tips on which tools to get would also be greatly appreciated as I’m just starting off with this wrenching stuff. I was recommended the following as a “starter pack”:
https://www.lowes.com/pd/Kobalt-227-...-Case/50200795 (frequently goes on-sale for $100 acc. PO)
https://www.lowes.com/pd/Southwire-D...Meter/50081424
https://www.lowes.com/pd/Kobalt-20-P...r-Set/50158893
https://www.lowes.com/pd/Kobalt-5-Pi...l-Set/50029422
Amazon
Amazon
https://www.northerntool.com/shop/to...BoCwkwQAvD_BwE
-but what would y’all recommend?
Thanks for the read!
Background:
Amazon
Amazon
