So, my original aux fan motor died earlier this week. I found a used e36 aux fan, motor, and shroud, and did the repair yesterday.
The donor aux fan assembly was not OE. Thus, the shroud, motor, and fan all had slight differences from the OE parts. Those differences are:
While the OE fan would and did fit the donor motor, I decided to use the donor fan to avoid a situation where the nut might loosen and the fan would not spin at speed with the motor.
So, I swapped the donor motor and fan to the OE shroud. I torqued the nut as best I could considering there's no way to hold the motor shaft while tightening.
Here's where I screwed up: Before reassembly, I removed about 4-5 rusted body nut clips from the donor fan blades. (Again, in the pic below, you can see the clips on the fan blades.)
I also removed from the fan shroud and the AC condenser any weather stripping that was disintegrating. I used compressed air blown into the AC condenser to remove any accumulated dirt/debris.
The initial test drive following installation was fine. The Aux fan came on when I turned the AC on, and the AC blew cold. I drove about 7-8 miles in local city traffic and there were a few sustained runs around 40-60 MPH. I did not experience any increase in noise, vibration, or harshness ("NVH"). The AC was on during the test drive.
But, a few hours later, there was a significant increase in NVH immediately upon start up when the AC turned on. Vibrations are felt in the cabin through the seat, and door panels audibly rattle. Increased noise comes from engine.
The vibrations subside when the AC is turned off. However, to isolate the problem, I turned the AC off but could still feel some smaller vibration when the radiator fan turned on. (The car does not have the mechanical fan. Rather, it has a 16" Spal puller on the back of Zionsville radiator.)
I'm really at a loss here, because everything was fine after it was installed. Obviously, the starting point is to replace the body nuts on the Aux fan blades.
Is there a method to properly balance the fan?
Could the partially removed weather stripping cause a disruption in air flow such that it would be felt in the cabin?
Could the compressed air cleaning have damaged a blade on Spal fan, even though it had to travel through the condenser and the radiator before hitting the fan?
Should I just go back to the OE fan, even though it's not designed to fit the flats on the donor motor?
Is this a dying AC compressor?
- The OE shroud has a slightly different opening at the top right, which I decided should stay in the event it directs airflow to somewhere in the engine bay. The donor fan has three protrusions (you can see in the pic below.)
- The donor motor has flats machined onto the shaft, and the donor fan fits onto those flats and is secured thereto with a nut. The OE fan fits the circular OE motor shaft and is secured with a circlip.
