OBC Help
    OBC Help
    I'm getting "Lic Plate Light Fail" on my OBC but both my license plate lights are lit and appears to have no problems. Any idea whats going on? Thanks in advance for any info.
    Even thou your lights are ok you should check the connections in the lic plate. It can exist a small gap in these connections causing false information to the obc. Try to clean with some contact spray. I already had this problem with other lights and this was the problem.
    Eduardo.
