wheel questions
    wheel questions
    The previous owner put a crack one of my wheels in the front im going to buy to new ones. I was just curious If i move the wheels i have on the back to the front and buy the wheels that are slightly wider for the back will everything work out? My car is a 95 and to my knowledge the wheels are the same size width front and back. but every other year the rear wheels were a little wider. Will they fit? also is there a noticable differnce? Thanks for your help guys.
    Wow, never knew the 95 was the only one with same size tires. Don't complain at least you can rotate them and get longer life out of your tires.
      Yes, you can pick up a set of 8.5" wide ten spokes for the rear, or just look for a set of Contours which were staggered from the factory.
