Leave it alone, that is not where you adjust the throttle cable. You can find that in the engine bay and have someone step on the pedal all of the way. At the same time feel in the engine bay and make sure it is opening all of the way. Chances are you are just fine.
If you mess with the bolt under the gas pedal, you can stretch or even break your throttle cable.
